Is-it possible to do a Dynamic Segmentation on descriptive tables?
  • November 16, 2017
  • 17 views
In the question https://knowledge.safe.com/questions/44413/lineonlineoverlayer-in-dynamic-segmentation.html
LineOnlineOverLayer is used to have the desired table. If I have the same first 2 tables (without geometries) and I’d like to do the segmentation before creating geometries to get the desired result like in the example, Is-it possible to do that?
thanks
Best answer by markatsafe
You can build a false geometry using the from/to values for the X coordinate (used the ID for Y) and then use the Intersector. You can avoid the conflict with the from/to attributes as described in the referenced article by recovering the start and end coordinate value. I've attached an example 2017.1 workspace.
dynamicsegmentationexample.fmw
  • November 17, 2017
  • November 18, 2017
it's work. Thanks for your help.
