Hello Team,
We have installed FME Server 2019 and published a workbench which was running fine with the FME Server 2015. But in newly installed 2019 server it was throwing following error.
oordinate system named NiSource_AE_US_Foot does not exist.
2019-12-12 08:49:53| 23.7| 0.0|WARN |Failed to get parameters for coordinate system `NiSource_AE_US_Foot' -- No definition was found for coordinate system `NiSource_AE_US_Foot'
2019-12-12 08:49:53| 23.7| 0.0|INFORM|FME API version of module 'GEODATABASE_SDE' matches current internal version (3.8 20190621)
2019-12-12 08:49:53| 23.7| 0.0|INFORM|Writer `GEODATABASE_SDE_1' of type `GEODATABASE_SDE' using group definition keyword `GEODATABASE_SDE_1_DEF'
2019-12-12 08:49:53| 23.7| 0.0|INFORM|An ArcGIS license is already checked out. The product checked out is 'Advanced'
2019-12-12 08:49:53| 23.7| 0.0|INFORM|Installed ArcGIS version is '?.?'
2019-12-12 08:49:53| 23.7| 0.0|ERROR |An error occurred while attempting to retrieve the connection parameters from the connection file 'E:\\SDEConnections\\GPSPreProdSDE\\sde@wgisdg12KY.sde'
2019-12-12 08:49:53| 23.7| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
Could somebody help me to get out of this issue??
Thanks in advance.
Thanks..
Nagendra
