How to automate parcel numbering
Kindly i need your help , i have a tool in map info that make auto numbering sequentially by clicking in feature
when i press on the feature the value in the record will increase or decrease by a value which i decide, i have to do it manually.
Is it FME capable to do same thing like mapinfo but in automated process.
Any advice.
Thank You
sigtill
Forum|alt.badge.img+24
  • March 12, 2013
If you run all features through the Counter everyone will get their own number (starting from 0 by default, or another value if you prefer). Not sure what you mean by "press on the feature" related to FME - however you can ofcourse increase or decrease the Counter-value if you want to, for instance based on another custom value.
  • March 12, 2013
if you need to increase or decrease an existing attribute value, take a look at the ExpressionEvaluator.
David
davideagle
Forum|alt.badge.img+21
  • March 12, 2013
You might also find the ModuloCounter an interesting option.
  • March 13, 2013
thank guys ..
i will try it ..
