I was wondering how I can remove the point that is generated with the text in the Labeller and/or LabelPointReplacer transformers? I want to generate contour labels but I don't want the additional point.
I am using FME2018.0 Desktop.
Thanks,
What format are you writing out to? I only see the extra point if viewing data in the inspector, once written out there is no extra point.
Thanks @egomm
You are right, when output to a file the points are not there. I was only viewing it in the inspector.....
