Schema based GML Writer
arvidsozols
Forum|alt.badge.img+3
Hi!
I am need to convert LV national data to EPRTR with Safe Software FME Workbanch. I am try to create GML Writer with using published XSD schema on: http://dd.eionet.europa.eu/schemas/EPRTRandLCPintegration/eprtrlcp_v_1.0.xsd
The GML Writer is not setting up! See in log file:
Starting translation...
FME 2019.2.0.0 (20191105 - Build 19801 - WIN32)
FME Desktop Oracle Edition (floating), FME Home Edition (node locked-crc)
Temporary License: 154 days left.
Machine host name is: GID-ArvidsO7
Operating System: Microsoft Windows 7 64-bit Service Pack 1 (Build 7601)
Copyright (c) 1994 - 2019, Safe Software Inc.
Safe Software Inc.
Creating reader for format: NULL (Nothing)
Trying to find a DYNAMIC plugin for reader named `NULL'
Loaded module 'NULL' from file 'C:\\apps\\FME\\2019\\plugins/NULL.dll'
FME API version of module 'NULL' matches current internal version (3.8 20190820)
Opened mapping File C:\\Users\\arvidso\\AppData\\Local\\Temp\\FME_1583926567576_11844.fmw for output
Mapping File Generation was SUCCESSFUL
FME Session Duration: 1.0 seconds. (CPU: 0.5s user, 0.2s system)
END - ProcessID: 12160, peak process memory usage: 38980 kB, current process memory usage: 38980 kB
What I am missing for? ...or XSD is for an other purposes? Please, help me!
Best regards,
Arvids Ozols
Hi @arvidsozols, I am not very familiar with the LV national data and EPRTR datasets. What formats are they in? I am assuming you would like GML for the EPRTR. I wondered if this article GML Writing with Application Schemas would help.
Would it be possible for you to share your workspace (.fmw file) or screenshots, so we could have more information to best assist you? Thank you!
arvidsozols
  • March 16, 2020
Hi!
I am find solution!
On the EEA Eionet was published documentation: https://cdr.eionet.europa.eu/help/eprtr_lcp/Documents/EPRTR-LCP_datamodel_v3.2.pdf
It described data schema and shows how additional information is added as Thematic (Emissions) Data to the INSPIRE GML in XML format.
I am added to my FME workspace XML Writer with schema published on Eionet repository http://dd.eionet.europa.eu/schemas/EPRTRandLCPintegration/eprtrlcp_v_1.0.xsd
Now I am trying to finish my E-PRTR and LCP integrated reporting data transformer for data providing to the European Environment Agency
Best regards
Arvids
