Issue with date time converter
  • February 19, 2020
  • 19 views
gogopotter90
Forum|alt.badge.img+13
i want to convert from date format 01.12.2000 to 2000 in one attribute
some times it is working great with my input excel files and some files show me this msg .
The below feature caused the translation to be terminated
DateTimeConverter_2_<Rejected>(TeeFactory): DateTimeConverter_2_<Rejected>
what is important for me to read the last 4 digit
Could someone provide me solution for this issue .
Thanks for help
Best answer by ebygomm
You'd normally get that message when you try and convert a value that isn't a date. If you only ever need the last four digits you could get this without converting the date using the following in an attributecreator
@Right(@Value(attrname),4)
But best to check the rejected data as it sounds like you have some data that doesn't contain a date. If you have some null or empty values, you can set the DateTimeConverter to pass through empty or null values
Forum|alt.badge.img+33
  • February 19, 2020
gogopotter90
  • February 20, 2020
Thanks for ur reply ,and explaination . i will check that
gogopotter90
  • February 20, 2020
@ebygomm Thanks man but i write left instead of right bcs it reads the date not correct,idk why 04.11.2010 it reads  2010.11.04 and u were right i have null in date but it is okey nw but do u know solution of readin date in wrong direction ,i did left instead of right so it is correct but if i want to fix it.what should i do
  • February 20, 2020
Do you have the input format set? Is the date you've given the 4th November or the 11th April? If the 4th of November the Input Format should be %Y.%m.%d$
