Statistic calculator working with dates
  • November 27, 2012
  • 47 views
jpvo
Participant
  • Participant
Hi guys,
I'm interested in having a statisatic calculator that would work with dates. I'd like to return the most recent date of an object set "group by" tile_ID.
Is there a way I could do this without a python caller?
Cheers,
JP
sigtill
Forum|alt.badge.img+24
  • November 27, 2012
Not sure if this is what you are after, but it might help anyway :)
I assume you have a DATE-attribute = 2012-12-10
Then you can use an attributesplitter on - and get a list, and rename these to something else
dates(0) = 2012, rename to year
dates(1) = 12, rename to month
dates(2) = 10, rename to day
Then you can use an Aggreagator on Tile_ID and a sorter to sort on Year, Date, Day for each Tile_ID.
fmelizard
Forum|alt.badge.img+18
  • November 27, 2012
Hi JP,
It would help if you can specify your date attribute format and type.
Itay
fmelizard
  • November 27, 2012
If you are using oracle a simple StatisticsCalculator will return the max of the date attribute and you can group it by a tile ID.
jpvo
Participant
  • Participant
  • November 27, 2012
I think I got the answer from you both. I use a date formatter to make sure I got FME Date (%Y%m%d) and then I can use the statistique calculator with "group by" tile_ID.
I tried earlier but with non conventional date format and got an error message from the StatCalculator.
Thanks!
