select group by Value
rakeshreddy0996
I have a filed like Language and Values as English, French, Italian, Hindi and Etc
But i don't know how many languages are present in that field.
Challenge: I would like to export separately for each language.
philippeb
Forum|alt.badge.img+20
  • January 6, 2020
Depends how the field is constructed, and I'm not sure to understand what you want to do, but if you want to know how many different languages contain that field, I would use a DuplicateFilter and set the parameter on that field.
Forum|alt.badge.img+49
You can set a fanout on the output feature type, use that attribute as the name of the feature and it will generate a separate output for every unique value.
rakeshreddy0996
@philippeb not only that, i want export those individual language as individual shape files also.
rakeshreddy0996
@redgeographics thank you
