Yes that's right the PATH reader in FME does not read hidden files in Windows as this point. You will need to change the properties of the file(s) so that it is not hidden. If you'd like to see this as an option on the Reader jump over to this idea here and vote on it!
Do any other users have any tips on this? Perhaps a quick workaround?
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
