Exctract values from a string (attribute value) ?
I have strings (ex New York : Ballantine Books, c2003, 2006.) what I'm interested to do is to get the year(s) out of that string to populate an other attribute.
In short, getting 2003 and 2006 in a different field. As dates are not always the same, regex would be best.
Is it possible? If so, could someone explain to me how ? Please.
Thanks.
Best answer by david_r
You can use the StringSearcher, e.g.:
This matches all groups of four digits in your string.
The years will exit in the list _all_years{}, e.g.
Attribute(encoded: utf-8)         : `_all_years{0}.match' has value `2003'
Attribute(encoded: utf-8)         : `_all_years{0}.startIndex' has value `19'
Attribute(encoded: utf-8)         : `_all_years{1}.match' has value `2006'
Attribute(encoded: utf-8)         : `_all_years{1}.startIndex' has value `25'
You can e.g. use a ListExploder after, if needed.
erik_jan
Forum|alt.badge.img+17
  • November 22, 2016
I would use the StringSearcher with a regex "\\d* ,\\d*$".
Follow by an AttributeSplitter (delimiter comma) or two SubStringExtractors.
  • November 22, 2016
  • November 22, 2016
Thanks for you answers, It worked.
I'll have to remember that All Matches List Name is putting match in a list.
erik_jan
  • November 22, 2016
@jacob1 Down voting an effort to try and help you is not the best way of showing appreciation.
  • November 22, 2016
Sorry, for the -1... it is an accident... not knowing how it works.
I'll pay attention next time.
Thanks to have answered my question.
Jacob1.
