Navisworks BIM data conversion
ekkischeffler
Forum|alt.badge.img+5
I'm looking for support with Navisworks (AutoDesk) BIM data (.nwd .nwf .nwc). I need to extract the full 6D information from the model and output it to other formats but also update the 6D information back to the model. Navisworks imports IFC but does not seem to export it. DWF, which can be written with Navisworks, does not hold the 6D information.
Any help would be appreciated.
Best answer by kailinatsafe
edualarcong wrote:
Hello @kailinatsafe​ It would be a major step for BIM integration to have at least a NWD reader. We work on a daily basis with NWD from different sources (Autodesk Plant 3D, Smart Plant 3D, Aveva) to push into ArcGIS, and the workaround at the moment is to use a IFC exporter plugin, but it is time consuming and not useful when handling large models or lots of geometries.
Hello @edualarcong​, thank you for commenting! This is great information, I have added a note about your potential use case. Please ensure to show your interest or vote on the FME Idea. Happy to help, Kailin!
mark2atsafe
Forum|alt.badge.img+43
  • April 25, 2016
Sadly the Navisworks format itself is not supported by FME (I guess you knew this already). We have an enhancement request (PR#54463) so I have added your request to it and increased the priority.
In the meantime, hopefully another user here has a workaround...
ekkischeffler
  • April 25, 2016
Aaron suggested to check for a JDBC option but I couldn't quite figure out how to go about that. Any suggestions?
mark2atsafe
  • April 27, 2016
I really can't imagine there would be an option for that. JDBC is for database connections, and I don't think nwd files are that kind of format. I've done a few searches and nothing tells me you could read them that way or connect to Navisworks through JDBC. All I can think of is to check the help/support documentation for Navisworks and see if it mentions JDBC. If it does, then we're in business. But I suspect it won't.
ekkischeffler
  • April 27, 2016
Thanks Mark, that's what I was looking for but couldn't find anything either.
Hello Mark!
Do you have any updates on the enhancement request (PR#54463)? I am also looking to translate a Navisworks file to GIS so that we can publish a flat 2d view of a Navisworks model to a web GIS interface.
Thanks!
mark2atsafe
  • November 2, 2017
stevemossfeldt wrote:
Hello Mark!
Thanks!
Sorry @stevemossfeldt there's been no movement on that enhancement request. I've added your need for it and increased the priority again. On the positive side there are a number of requests now and a high user priority, so it gets a higher development priority because of that. On the downside it's going to be a big project to add this format, so I can't see it happening soon. Definitely not for 2018.
If you (or anyone) has a compelling business case - for example a huge sale depends on the format - then do let us know, either via support or our sales team, and we'll do what we can to help.
ekkischeffler
  • November 20, 2017
Thanks Mark. We now have several cases where we would like to consume the Navisworks format to bring BIM models into GIS. Many projects use Navisworks to collate and manage the federated model. Going back to the individual models doesn't work so well as information might be added or changed in Navisworks.
I might get back to you as suggested with a specific case.
Thanks for following up on this.
jpvo
Participant
  • Participant
  • September 10, 2019
This topic needs more support. This is very much related to any BIM project and later down the line to Augmented / Virtual Reality. Efforts in supporting augmented reality format goes along with more support on BIM format.
@mark2atsafe Any news with PR#54463 ? Thanks
mark2atsafe
Sorry, no update on that. Other customers have asked for it recently too, and I know it is closely aligned with AR efforts, so I'll try and push it forward as best I can. I'll let you know whatever I hear back.
mark2atsafe
Oh, fyi (more a note to myself) the new reference number is FMEENGINE-9601
mark2atsafe
So the news I have is that the 3D/BIM team are working on three key items: polishing the Revit reader, completing ArcGIS 3D support, and adding the Navisworks format. Navisworks is the lesser priority right now, but I can say that it's almost certainly going to happen soon (I am rarely that specific about future plans so you know I got this from the top). My guess is that it'll be a medium-term project: so not 2020, but hopefully not long after that.
To help move it along it would help to know what scenarios everyone is interested in. My suggestion would be to add this information to the current idea (https://knowledge.safe.com/content/idea/18902/nwc-navisworks-cache-file.html) - and upvote it of course - stating whether you are interested in reading or writing, and what specific geometries you are interested in (I know next to nothing about the format but the more user info we have the better the product will be)
Hey Mark!
Is there any update reg this question?
Our customers are searching for a tool to access NavisWorks models (changing) from 2d/3d GIS.
Thanks you,
Kirill
mark2atsafe
  • August 4, 2020
Well, coincidentally the CAD team were asking this morning for input on their roadmap going forward. I've indicated very strongly that this format should be top of the list and done in the near future, else we risk losing users. Other people seem to agree. So the bad news is that we don't have support right now, but I'm very confident that it will be worked on for 2021. I mean, no guarantees, but I'd be shocked if we didn't.
Hi Mark, I'm looking at FME2021 desktop and looks can't find a reader .nwd file. Did this miss the list for 2021 release? Can we expect in in 2022?
fgiron
Forum|alt.badge.img+20
  • March 16, 2022
Hi @mark2atsafe​, I understand this didn't make it to FME 2022.0, but do you know if there is maybe any plans for 2022.1 or later?
jpvo
Participant
  • Participant
  • July 4, 2022
Hello @mark2atsafe​ any news on Navisworks support? The interest is growing over the years. Thanks
kailinatsafe
Forum|alt.badge.img+19
Hello @jpvo​ , sorry to be the bearer of bad news, unfortunately, support for Navisworks is still unplanned. Have you added a comment or upvoted this idea here yet? It would be nice to learn what you're trying to itegrate with Navisworks. Best, Kailin.
edualarcong
  • August 23, 2023
kailinatsafe
  • August 24, 2023
edualarcong
  • August 24, 2023
Thanks! @kailinatsafe​ I voted on the FME idea and added a related idea about Smart Plant 3D (VUE file reader). It is a workaround focused on BIM models stored in VUE files. If you need examples or details for use cases, we are glad to help. Regards!
umapper1
  • February 28, 2024
What’s happening with this Navisworks format support? I can’t find the idea page to upvote it and it appears the format has been under request for 7 years now. Could we get an update as to whether it’s being worked on or shelved?
jasperwis
Forum|alt.badge.img+15
  • March 22, 2024
Hi @kailinatsafe @mark2atsafe
Can we get an update please? This was with the developers 4 years ago.
What is the current status? Is it still on the roadmap?
ODA - Open Design Alliance (already known to Safe Software) has a Navisworks SDK available: https://www.opendesign.com/products/bimnv
A lot of FME users are clearly waiting for this and this is a showstopper/must have for several customers.
But now it appears that even the idea has disappeared
Best,
Jasper
kailinatsafe
Hello @jasperwis, thanks for checking in! Right now, our focus is on developing a new and improved IFC Reader. Navisworks is high on our list of considerations for future development, but it hasn’t entered the active development phase just yet.
We appreciate your patience and the push from our FME community. We'll definitely keep your feedback in mind as we shape our roadmap. Happy to help, Kailin.
kailinatsafe
Hello All! Hope this message finds you well. Great news! A Navisworks Reader will be included in FME Form 2024.2! When it becomes available, you will be able to find it on our Downloads Page. We encourage you to try the new reader and give us feedback here! Happy to help, Kailin.
deanatsafe
  • August 24, 2024
Good news! As an update to @kailinatsafe comment above, I’m happy to report that we just added support for reading Navisworks and this is now available in our 2024.2 beta!
See FME 2024.2 beta b24729 or later - see: https://fme.safe.com/downloads/#beta
