Create multiple polygons based on a table join
I have a polygon feature class and a table in a file geodatabase. There are multiple rows in the table for a given polygon in the feature class. I want to create a new polygon feature class with polygons for every match in the table. I have tried Matcher, which seems to work, but it is not populating the Shape Area and Shape Length. Anything else I should look into?
Thanks,
Srini
Best answer by mark_f
Have you looked at the FeatureMerger transformer?
  • March 12, 2013
  • March 12, 2013
Perfect, that worked. Thank you!!
