Does the FME installer produce a log file?
fmelizard
Forum|alt.badge.img+18
I'm trying to install FME but I am getting errors. If there was a log file, it might be helpful to identify what is going on!
Keywords: desktop install log server install log command line install
Best answer by andreaatsafe
I'm pleased to announce that an installation log file is automatically created when installing FME 2021.0 and newer when using the Setup.exe after extracting the files.
rylanatsafe
Forum|alt.badge.img+13
  • December 5, 2016
You can run the FME installer using the command line and specify that it log out to a text file.
Use the following command inside a Command Prompt as Administrator, with the appropriate FME installer filename:
msiexec /i fme-desktop-b15573-win-x86.msi /l*v log.txt
fmelizard
  • March 14, 2017
The same applies for FME Server:
msiexec /i fme-server-b19999-win-128.msi /l*v log.txt
erik_jan
Forum|alt.badge.img+17
  • March 14, 2017
Would be great if this was an option in the installer wizzard, or the default setting.
I don't see many of my customers using a command line like that.
itay
  • March 14, 2017
you have my vote for this idea....
erik_jan
  • March 14, 2017
Done: https://knowledge.safe.com/idea/41291/installation-log.html
itay
  • March 14, 2017
andreaatsafe
Forum|alt.badge.img+12
  • March 16, 2021
