Retime gpx-files
aron
Forum|alt.badge.img+16
I need to set new timestamps to a set of polylines that is to become gpx files and have two questions:
1. How do I set what end is the begining of the line?
2. Is there some way to start the timestamp at a specified time? Say I wanted it to begin at 01-01-2000?
danilo_fme
Forum|alt.badge.img+41
  • May 27, 2020
Hi @aron
1 - To extract the begin and end of line you can use the transformer CoordinateExtractor - using these configurations:
Begin of line: Index = 0
End of Line: Index = -1
Like image bellow:
Thanks in Advance,
Danilo
aron
  • May 28, 2020
danilo_fme wrote:
Hi @aron
Like image bellow:
Thanks in Advance,
Danilo
Thanks @danilo_fme! What I want to do is to set the starting point myself. I suppose the simplest would be to check what end of the line is closest to a point object and then set that end to index = 0. How do I set that instance to Index = 0?
danilo_fme
  • June 1, 2020
Hello @aron
The transformer Orientor can be used for change the oreintation of line.
Thanks in Advance,
Danilo
