convert xml to csv
  • May 17, 2016
  • 117 views
Specifically, I would like to know how to abstract the lat/long coordinates from AIXM 5.1 and convert them into a readable csv file....(for aviation purposes)....can this be done? Thank you
Specifically, I would like to learn how to acquire the lat/lon coordinates and turn them into a readable csv file....can this be done? Thanks.
Forum|alt.badge.img+5
FME reads AIXM (it has a specific AIXM reader) so you should probably use that. Then you can extract the coordinates of features with the CoordinateExtractor transformer. From there you need to add a CSV writer, add some field definitions to it, and map your extracted coordinates to them.
Sounds like you might be a relatively new FME user. Please do feel free to make use of our support team (safe.com/support) or use the chat option on that page to talk to someone directly.
