Is there currently any way to get FME to work with ESRI enterprise geodatabase objects that have Arcade expressions? We'd really like to customize our feature popups and Arcade is the only language to code them in in ArcPro. But if we do that, it appears we can no longer use FME to translate data into the features. (We get same message "The item does not have a definition" as we got when we tried to run an FME translation last year after adding an attribute rule to a feature using Arcade in ArcPro.)
Here's an example (Note that we added custom popups to FireServiceConnection yesterday.):
2019-03-19 09:58:26| 41.9| 0.6|ERROR |An error occurred while attempting to open the table, feature class or relationship class 'sde.FireServiceConnection'. The error number from ArcObjects is: '-2147211773'. The error message from ArcObjects is: {The item does not have a definition.}
I saw an idea https://knowledge.safe.com/content/idea/76658/add-readerwriter-support-for-esri-arcade-expressio.html was added last year for this functionality.
