As it says, is there any log file or something that will give me information what are older values of token for some particular user? I also need a time information of how long did old token last (from-to).
We experienced restart of a token but we don't know why...
We're working on FME Server 2017.1.
Best answer by gerhardatsafe
Hi @zzupljanin,
In FME Server 2017 you can only check if there is a valid token available for a user with the FME Token service. I do not think can retrieve any information about expired tokens.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
