Regex, case insenstive matching and micro µ v greek letter mu ?
  • July 1, 2020
  • 68 views
Forum|alt.badge.img+31
Is it correct that if in a StringSearcher Case Sensitive is set to no that the expression \\x{03BC} should match both the micro symbol and the greek letter mu?
\\x{00B5} also matches both if case sensitive is set to No
  • July 2, 2020
The re-module in Python3 seems to agree with the StringSearcher in this case, it gives the same "cross-matches" when the test is set to case-insensitive. However, the case-insensitive tests also give a positive match for the listed uppercase-character: https://www.fileformat.info/info/unicode/char/039c/index.htm , so I'm not sure what the reason is.
