Hi all, I have a roads shapefile that is a polygon. When I convert it to a DWG using FME it comes in as a series of blocks. I have a few things that I need to do.
- Explode the blocks so that they aren’t polygons any more. I’ve tried: geometry coercer and deaggregator but neither of these explode the blocks.
- I need to be able to style the file as follows:
- Blue
- Weight 0.5mm
- A particular dash line type.
I have created a polyline in a dwg with the style I want and used DWGStyler to select it but I can’t seem to get it to work, does the layer in the template and the layer that is to be written have to be the same name?
Thanks
