I've a large installed base of Revit with versions from 2016 to 2018 and one of the worst problems we are dealing with is the incompatibility between these versions. I would like to know if FME Destkop can act as an intermediary in order to read from one version and write to a different one. Maybe the plugin for Revit and the rvz format could be the solution, but I'm not sure about this (I didn't have explored this). Thanks a lot!
Revit support in FME Desktop
Best answer by daveatsafe
Hi @jcglez2,
FME can currently only read Revit data (through the RVZ exporter). We are working on adding both direct Revit reading and writing, but this is a long term project.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
