How to make readers without input not throw an error ?
I'm attempting to run a workspace that calls other workspaces (on an FME Server), collecting and passing a list of path names as input to the detail workspaces' readers.
When no path names are available for a specific reader (they're read from a db table), a blank string is passed. This however yields an error (when the reader apparently tries to open a file with a blank name), crashing the whole workspace.
Is there any way of disabling one or more readers based on a blank input ?
If not, Safe, this is an enhancement suggestion !!!
Cheers
Lars I Nielsen
  • March 28, 2014
have you tried to enable "Ingore failed readers"?
David
Hi David,
Doh, I overlooked that in the setup. And so did my much more experienced colleague :-)
Thanks! I've resubmitted my workspaces, hoping it'll work this time (takes an hour to run).
Cheers
Lars I Nielsen
