FME Server radio button
  • September 7, 2018
  • 6 replies
  • 28 views
I have had a look to see if a radio button is available as a user parameter for an FME app that is pulling the parameters back using fmeserver.js.
<form id="fmeForm" name="fmeForm" onsubmit="return dataDist.orderData(this);" onchange="dataDist.updateQuery()">
Does anyone know if this is doable?
  • September 7, 2018
Do you mean using the generateFormItems() method?
  • September 7, 2018
Hi @david_r
Yes, the items get generated but would like to use a radio or selectbox for a single selection but the only option i can find that does selectboxes are multiple's from the user parameters.
Regards
  • September 7, 2018
Radio boxes aren't implemented in the generateFormItems() method, so you'll have to implement that yourself.
The easiest is probably to write a custom version of generateFormItems() that implements your particular requirements and then use that rather then the one supplied in FMEServer.js
  • September 7, 2018
If you just need a quick hack you could try modifying line 546 in FMEServer.js as follows:
checkbox.type = "radio";
  • September 10, 2018
@david_r - thanks for the info. Do you know if its easy enough to target one of the radio buttons? I can see if creates a span but unsure how easy it would be to dynamically target one to add a link to it for futher information?
thanks
thanks
I think you've reached the point where you'll probably want to roll your own implementation of the generateFormItems() method (which I suspect was included mostly for demonstration purposes). You can copy/paste the function contents from FMEServer.js and modify it as needed.
For someone that knows a little bit of javascript it should definitely be possible to achieve what you're asking.
