I want to call same workbench again based on some feature at shutdown.
I achieved this through a python shutdown script but the problem is i also want to set the user parameter for the next run. I tried but each time the workbench runs again, i takes the default value of parameter.
Is there any way to set the parameter at shutdown so that next time when workbench runs it picks the value i set ? Any help would be appreciated. Thanks in advance.
