When using AppearanceSetter you can for instance drape an ortophoto on top of a terrain modell. However it seems the texture gets scaled down to a lower resolution. What is the maximum raster pixel*pixel allowed for a single surface? Is it possible to increas this to get a more detailed model?
Are there also some limitations when writing this surface with texture to formats like Sketchup 3ds etc?
