Reproject ITRF -ccl to WGS84 or UTM
  • November 24, 2017
  • 22 views
acolliere
Hello. I'm in México. The official Coordinate System is ITRF82 - CCL. Reprojector can't read this coordinates system, so I can't reproject it. Please if someone caould help.
acolliere
  • November 24, 2017
Aló, Je suis au Mexique oú le systeme officiel de coordonees est ITRF - 2008 , CCL . Le FME "Reader" ne peut pas lire les coordonees, donc il n'est pas possible de realiser la reprojection á WGS84. Il-y-a quelqun qui pourrait m'aider, SVP. Merci d'avance
  • November 27, 2017
I don't have any knowledge about that specific coordinate system, but it is possible that you'll have to make a custom coordinate system definition in FME.
Here's a article to get you started: https://knowledge.safe.com/articles/585/using-coordinate-systems-within-fme.html
This page seems to have the needed parameters for the ITRF definitions: https://confluence.qps.nl/pages/viewpage.action?pageId=42315393
You could also try looking up "ITRF" here: http://www.epsg-registry.org/
Finally, there's also this post on StackExchange that might give you some pointers: https://gis.stackexchange.com/questions/28268/how-to-define-itrf-92-and-itrf-2008-using-proj4-parameters-in-qgis
Bonne chance!
acolliere
  • November 27, 2017
Hello David, thankyou so much for the time devoted to reply my answer. I'll follow your suggestions.
Have a nice week.
Merci Beaucoup
nampreetatsafe
Forum|alt.badge.img+13
Chatted with @acolliere​ about this during the Partner Summit and wanted to update this post. The PROJReprojector and EsriReprojector will support the desired coordinate system (ITRF92 / LCC, EPSG:6362) as shown below:2020-12-02_17-10-052020-12-02_17-10-21
