Tolopoly Builder wont break polygon
jugoslaviaa
I have two polygon datastets and i send them to the Topology Builder so that they will get break at the intersection. However it does not give the result I expected. My expectation would be a similar result to thearea on area overlay
my output looks. The overlapping area are not broken. Any idea what i may have been doing wrong
Best answer by redgeographics
Try the AreaOnAreaOverlayer instead, that should break up overlapping polygons.
Forum|alt.badge.img+48
  • April 30, 2024
jugoslaviaa
  • May 5, 2024
I know that areaonareaoverlay gives the result I expect as I have written in the question. I wanted to know why the topology builder doesn't  do.
danilo_fme
Forum|alt.badge.img+41
  • May 5, 2024
Hi, Please - could you share us the dataset for test?
joepk
Forum|alt.badge.img+20
  • May 6, 2024
Simply put: because it is a different transformer. The TopologyBuilder computes topological relationships between input features and outputs those topological relationships. The AreaOnAreaOverlayer simply intersects the input features and outputs the geometrical result.
