Archived
WFS Reader - Using Parameters in Feature Type Setup
Related products:Integrations
chriswilson
The WFS reader currently does not give the option for parameters to be used inside the feature type setup, e.g. for a search envelope. These can be set in the navigator window after adding the feature type, but it would be useful to set them in the initial dialog.
" target="_blank">https://fmecommunity-ideas.s3-us-west-2.amazonaws.com/2018-09-07-13-47-11-multi-none-mahnamahna-arcgis-t.png">
