Archived
CSV Reader: modify/set field names
Related products:Integrations
siennaatsafe
danilo_fme
jdh
geosander
+3
  • siennaatsafe
    siennaatsafe
  • david_r
  • danilo_fme
    danilo_fme
  • jdh
    jdh
  • geosander
    geosander
  • neilmyoung
    neilmyoung
  • cwarren
    cwarren
  • eadonan
geosander
In the CSV reader parameters dialog, when Attribute Definition has been set to "Manual", I would very much like to be able to change the field names. Currently (FME 2018.1), I can only change the attribute types.
Especially when Field Names Line has been set to "None", and all the attribute names are automatically set to "col<n>", this would come in handy. Now I need to use an AttributeRenamer/Manager to change the field names afterwards.
Why can't we do it in the Parameters Dialog? It'll save some clicks and it keeps the workspace tidier.
LizAtSafe
Forum|alt.badge.img+15
  • April 5, 2025
OpenArchived
LizAtSafe
  • April 5, 2025
Editing the input attributes within the reader is locked by default to prevent schema conflicts, however, editing can be enabled via the FME Options. See https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/options_workbench.htm under Reader/Writer Options for more details. We recommend using the AttributeManager or AttributeRenamer however to modify attribute names.
