How to store username and password securely that can be used for getting a token
ewb_fme
Forum|alt.badge.img+4
At the moment I get a token with a normal HTTPCaller with username and password as User parameters. However, I would like to store username and password secure. For this reason I tried to use a Web Connection. Unfortunately this didn't work. Any recommendation hwo this should be done?
This is my HTTPCaller that works fine but with the drawback that username and password are defined as user parameters in plaintext.
Bild 1
nielsgerrits
I think you should be able to create your own Web Connection to do this. (Tools, Options, Web Connections, Manage Services, + to create new Web Connection, I think Token Service.)
virtualcitymatt
Forum|alt.badge.img+34
Plus one for this option - the fme doc could use a little love in this space but you should be able to get it to work with some experimentation
nielsgerrits
I was also looking for a tutorial or article on how to do this, but I found none. Is there other documentation than the help?
virtualcitymatt
Here's a tutorial for a token based service - it's pretty light though: https://community.safe.com/s/article/Creating-a-TOKEN-based-Web-Service-in-FME-Yelp
There's also this one on Oauth 2 - https://community.safe.com/s/article/Web-Connections-and-FME
And here's a more general overview: https://community.safe.com/s/article/Web-Connections-and-FME
nielsgerrits
Thanks!
