How do you populate missing/null feature attributes from values of a single feature?
lorenrouth
Forum|alt.badge.img+8
Here is another simple-yet-not question:
I am working with a large pdf and want to populate pdf_document_info_metadata attribute values for every feature.
I have tried: FeatureMerger, Joiner, Aggregator, AttributeValueMapper, NullAttributeMapper, AttributeManager (trying to use Adjacent Feature) etc.
This should not be that hard, but I'm at a loss. Any ideas?
Thanks,
@lorenrouth​
Best answer by nielsgerrits
FeatureMerger with values 1 for both Requestor and Supplier. (Like 1=1, it will match the supplier to each requestor.)
nielsgerrits
Forum|alt.badge.img+54
  • December 8, 2021
lorenrouth
  • December 8, 2021
Hi @nielsgerrits​ ,
Yeah, I tried that first but it didn't work. Here are a few screenshots:
popfeature1popfeatureI merged on the Counter value as well as fme_feature_type, but no dice.
lorenrouth
  • December 8, 2021
lorenrouth wrote:
Hi @nielsgerrits​ ,
Wait, you mean actually using "1" to join on! OK it works now.
Thanks!
