Hi All, I have a complex polygon with smaller polyons within a bigger polygon, multiparts and lots of overlap issues. I want to be able to desegregate, remove multiparts and be able to select each polygons individually. Any thoughts will be helpfu
Hi All,
I have a complex polygon with smaller polyons within a bigger polygon, multiparts and lots of overlap issues. I want to be able to desegregate, remove multiparts and be able to select each polygons individually. Any thoughts will be helpful.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
