Adding colour to 3D Geometries where the colour code is stored as an attribute value
Screenshot 2021-06-02 103136I am trying to add solid colours to elements in a 3D model. Each element in the 3D model has an attribute where I have stored the hex code for the colour of that given element.
I can't seem to get the colour to work - I have tried using the the apearance Styler followed by the appearance setter but it quite often says that the colour codes are invalid - or if they are valid nothing changes
caracadrian
Forum|alt.badge.img+23
  • June 2, 2021
AppearanceStyler uses RGB values ranging from 0 to 1.
For this reason White ffffff 255,255,255 has to be converted to 1,1,1 or Blue-ish 00aaff 0,170,255 to 0,0.666667,1.
When you set the color manually, AppearanceStyler auto-converts it to the right value after you click OK but if you set it via attribute you have to normalize the RGB values.
  • June 2, 2021
Hi @caracadrian​
Thank you for the quick response!
I have since converted my hex values to RGB values and normalised these so that they are between 0 & 1 - however all features are still being rejected by the AppearanceSetter with the fme_rejection_code: EXTRA_APPEARANCE_FEATURE.
Do you know what this menas and how I can fix it?
Thanks!
caracadrian
  • June 2, 2021
izz88 wrote:
Hi @caracadrian​
Thanks!
As in the screenshot of your workspace, AppearenceStyler is not fully configured (note the red cog on the transformer).
Can you supply a sample of your data and/or your workspace?
  • June 4, 2021
izz88 wrote:
Hi @caracadrian​
Thanks!
Hi @caracadrian​
I have attached a sample of my data and workbench.
Thanks for your help!
caracadrian
  • June 7, 2021
izz88 wrote:
Hi @caracadrian​
Thanks!
I can't read your gdb sample with the GDB OPEN API.
FileGDB Reader: Feature class 'Beams' has shape type 'esriGeometryMultiPatch' which is unknown to FME. Skipping feature class
Try setting Appearance Name in AppearanceStyler to ObjectType attribute, then do the same in AppearanceSetter.
Also, Appearance Join Attribute and Geometry Join Trait are important in most cases.
