How to know which user removed workspace from FME Server?
zzupljanin
Forum|alt.badge.img+4
Does it say anywhere on FME Server (logs or something) which user removes workspace from repository?
thank you
sigtill
Forum|alt.badge.img+24
  • November 30, 2017
Which version of FME Server? In FME Server 2017 you have much more control over which repositories each user can access - and only allow some users to publish and alter some of the repositories. I do not think there is a "delete log".
zzupljanin
  • November 30, 2017
Yes. I'm using FME 2017
rylanatsafe
Forum|alt.badge.img+13
  • November 30, 2017
Hi @zzupljanin - Please consider voting for this idea and adding additional comments!
https://knowledge.safe.com/idea/35677/activity-log-audit-trail-activity-history-traceabi.html
zzupljanin
  • January 12, 2018
Yes, I also think that. But last month I bumped into something called Version control in FME. It's still sort of in testing phase but with this you could actualy follow which user does what on some repositories.
