Check status using Job Id
  • December 1, 2017
  • 92 views
recently I try to use Job id to check status of my submitted job on FME Server, based on FME Server Playgound, I try to use Get method to call this url:
http://apptest:8080/fmerest/v3/transformations/jobs/397; this case job id is 397, authentication use token, I use browser of postman both get results:
"message": "null for uri: http://apptest:8080/fmerest/v3/transformations/jobs/397". If I login FME Server, I can see the job is finished success. My question is how to get "STATUS", "RESULT DATA" information as attached below image. Thank you very much.
Best answer by allensong
I missed id in URL, the issue resolved. Sorry.
  • December 1, 2017
