AUTOCAD WRITER Unused Objects
franco69
Hi there Guys,
i had a topic about few days ago.....
i have an autocad file where i want to write not all layers from the template (only the layers which comes with an feature type in the reader).....tha i solved with help from you with the parameter: PURGE UNUSED OBJECTS
So now i have following problem with one layer:
layer 0 has a block included which i have to explode and also use block feature type for components i have set on YES
this block has include some layers i dont want to write (because of purge unused.....)
but they be written. (maybe because they are originally included in a layer which has a feature type?)
how can i explode the block, take the original layer definitions with me and filter the not used layers (parameter?)
I've tried also the REAL DWG Writer
Thanx and Greetz
Franco
Be the first to reply!
