More about Regular Expression (RegExp)
parashari
Hi All,
I have, many times came across the transformers that use RegExp but I am not sure about how to use it intelligently. I have also read some Q&As; from @takashi and @gio and from tcl site and I was wondering if I could use it more efficiently. I would like to understand more about the codes and expressions. Can someone help me with that?
davideagle
Forum|alt.badge.img+21
  • January 27, 2016
Some good websites to use to get you started are as follows...
General Help:
http://www.regular-expressions.info/quickstart.html
Testers:
http://rubular.com/ - my favourite
http://www.regexr.com/
http://txt2re.com/
  • January 27, 2016
Hi
Regular expressions have been around for a long time and are used not only in FME, but in many programming languages and applications.
If you look around on the web you'll find a lot of free tutorials and references. I particularly like this reference.
There are also many books on the subject, in particular I'd recommend
David
erik_jan
Forum|alt.badge.img+17
  • January 27, 2016
The Help of the FME transformer StringReplacer contains some examples and a link to the Rubular test site.
gio
Forum|alt.badge.img+15
  • January 27, 2016
Check out this very complete explanatory work from
Regular Expressions
The Complete Tutorial
Jan Goyvaerts
It used to be a free download, nowadays a little contribution is required.
his website
http://www.regular-expressions.info/cookbook.html
Rubular is handy, but is flavor limited. Notepad++ you can also test and built them as are Regbuddy etc.etc.
FME has mixed hadnling of regexp (wich i hope will be solved.)
Fme cant even find and replace a comma using a regexp..lol. (use the unicode string to this) Stringserachers & co. are very limited, no switches, forward lookups etc..
Best to use tcl regepx in attribute creators, testers etc. Basicaly everywhere you can use an expression u can use tcl regexp commands.
  • January 28, 2016
Related information. In FME 2016.0, the Regular Expression Editor has been introduced. You can use this editor to enter a regex to a regex parameter field of some transformers (e.g. StringSearcher) and test your regex with any test string.
davideagle
  • January 28, 2016
Excellent find Takashi, thanks.
