Error in custom transformer VideoPropertyExtractor
danilo_fme
Forum|alt.badge.img+41
Hello FME' users,
I'm try to extract some informations from Video ( .mp4 extension ) using the custom transformer VideoPropertyExtractor.
First, I downloaded the ffmpeg and installed all packages in the folder.
Using the transformer Creator -> I configureted the custom transformer, like bellow:
The Workspace executed without success:
Attached the log file -
FME Version 2019.1 - Build 19608
Command Line is Works:
Thanks in Advance,
Danilo
scyphers
Participant
Forum|alt.badge.img+5
  • Participant
  • August 19, 2019
Oi Danilo :)
I replicated your issue, i think the VideoPropertyExtractor in Hub has a disconnected published parameter. Edit the custom transformer and swap out ""ffmpeg.exe" in the first AttributeCreator for the parameter of $(FFMPEG) and see how you go.I think the syscaller was calling an incomplete reference.
Boa Sorte ;)
danilo_fme
  • August 19, 2019
scyphers wrote:
Oi Danilo :)
Boa Sorte ;)
Olá @scyphers
Your tip and clinical look inside this parameter was spectacular :)
Muito Obrigado!
Danilo
