Expose AutoCAD 3D polyline z-value
  • October 11, 2013
  • 108 views
I'm trying to import some AutoCAD contour lines and write them to a shapefile.  I need the z-value to be included in the shapefile as an attribute.  I've got the reader and an attributeExposer set up.  I cannot seem to find which AutoCAD attribute is the z-value of the lines.  I've tried writing all attributes that have a Z in the name, but each time the shape file has an empty elevation attribute.  Any ideas?
  • October 12, 2013
If the contour lines read from CAD are 3D geometries, you can use the ElevationExtractor transformer to extract z-value as an attribute.
Takashi
  • October 15, 2013
Thanks, Takashi, that worked.  So obvious, but alas, it was Friday afternoon!
