Hello everyone,
I am having random timeouts on FMEServer when i am trying to connect to a PostgreSQL database (using FeatureReader/FeatureWriter) or when i am trying to realize a simple get/post with HTTPCaller. The timeouts seems to happen randomly, mostly when there are multiple simultaneous jobs.
The HTTPCaller timeout is partially solved by activating the option "Retry Failed Requests", but sometimes the maximum value of "Maximum Retry Attemps" (10) is not enough (i.e. the timeout is still there after 10 retries).
For the FeatureReader/FeatureWriter there is no retry option available.
A similar problem was found here It seems that i have an unstable connection to my postgres db, sometimes it will read from it and other times I get this error message: (safe.com) but there is no hints to the source or solution of this error.
Some details:
FME Server 2022 Build 22792 with 5 engines
Using Linux (RHEL 8.7) with docker
Thanks in advance
