I have a workbench set up for labelling features using MapTextLabeller. I have noticed that lines that are near-vertical but slanted slightly towards the left (i.e. bearing 358 deg - 359.9 deg with 360 deg being straight up) are not labelled according to cartographic best practices. Labels should always read from left to right. A line that is slightly slanting to the left (at the top) should have a label that reads from top-left to bottom right. But the transformer is doing the opposite. Lines that have a more exaggerated slant are labelled correctly. Is there a way to force the transformer to somehow follow this cartographic labelling principle?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
