Left Outer Join and maintain record order
  • November 22, 2021
  • 59 views
rtreecare
I have 2 readers. I am trying to add new fields and values from the 2nd reader to the 1st reader if there is a match. There isn't always a match and I want to keep the order of the records in the output. I'm trying both featuremerger and feature joiner but neither are reproducing what I expect.
Job_Line_exampleThe featurejoiner failed because not all job records have a lineID. I still want all jobs in the output.
One note is there the Lines have a 1:M relationship with Jobs. There is only 1 line record that would populate the output new fields.
Thanks!
rtreecare
  • November 22, 2021
For anyone wondering, I followed this workflow with NullAttributeMapper:
https://community.safe.com/s/question/0D54Q000080hfLU/question-of-the-week-merging-data-with-the-featurejoiner
Line_Job_Tree solutionI had to set null keys to "NONE" before FeatureJoiners and then set them to null after the join.
