Find condition attribute
Hello sir / madam,
So I have two attribute "_zmax" and "ROOFLEVEL".
So I want to test if "_zmax" value is within 5m of "ROOFLEVEL". If yes, then "Pass". If not, then "Fail".
So if "_zmax" is 10m, then acceptable value should be 5-15m.
Might I ask how to do that?
Should I use attribute manager transformer?
Thank you in advance.
geomancer
Forum|alt.badge.img+48
  • July 20, 2022
Take a look at the Tester and the TestFilter transformers. Both can provide the testing you are looking for.
Testing
Got it! thank you for your help! :)
