Translation from dxf file to MapInfo creates only one layer, the last one even if it can see all of them.
  • February 23, 2021
  • 10 views
I have the new version. The old one used to do this very easily.
danilo_fme
Forum|alt.badge.img+45
  • February 23, 2021
Hi @rene_audet​
Is there some configuration in the Writer for fanout attributes?
Please, could you share our Workspace template? What version of FME are you using?
Thanks in Advance,
Danilo
darkspatiallord
do you have a single feature type foir the dxf? and how many writer feature types do you have?
  • February 23, 2021
I used to run the translator from within MapInfo and it was running all smoothly. I also could select to open non-empty layers only and specify line type, color, etc all from one small frame.
Now, what I get in FME Workbench is a bunch of yellowish arrow shaped objects - one for each layer, that I must run separately and eventually view in a window. The problem is probably that I am unfamiliar with this software that is very awkward for me to operate. So, frustration. I liked it much better when it was integrated to Mapinfo. Also, I am a self entrepreneur and can't afford to spend much money or time on software. I must make do with small resources and deliver my product - environmental maps for small lots. Thanks.
