Create a relationship between excel files and Shapefile and publish it in an FGDB
  • January 12, 2022
  • 6 views
arash_hokm
Forum|alt.badge.img+8
I'm trying to create a relationship (1: n) between a shapefile and four tables and publish it in an FGDB. I created two columns with AttributeCreator (goedb_feature_has_relationships) and (geodb_oid).
Canvas_relationship
As a writer, I have four options (see the following figure). I selected (Esri Geodatabase (File Geodb)).
WriterI noticed that format attributes from my writer doesn't contain (goedb_feature_has_relationships) and (geodb_oid). It is the same with other writers. Because of this, no relationship is created in the end.
geodb_oidgoedb_feature_has_relationships
every excel file has a relationship (1:n) with my shapefile.
I would be grateful if you could tell me why the problem is. Many Thanks.
Best answer by nielsgerrits
Did you create the relationship classes in ArcMap/ArcGIS Pro before try to fill them with FME? Also see this article.
nielsgerrits
Forum|alt.badge.img+54
  • January 12, 2022
