Extract mask from raster
  • November 28, 2019
  • 79 views
Good afternoon. I have one raster with 4 bands (RGBA). The alpha band shows transparency (255 is transparent and 0 is opaque). Furthermore I have another raster that I have to multiply with first. Is it possible to extract any values (i.e R=179,G=227,B=249,A=255) and set alpha band as 0 (opaque) and leave the rest of raster with its original values for multiplying later?
Thank you at all.
jdh
Forum|alt.badge.img+28
  • November 28, 2019
Normally the alpha band works in the reverse. Values of 0 are transparent and 255 are opaque.
That said, you can use the rasterExpressionEvaluator with conditional expressions. https://knowledge.safe.com/articles/1226/using-conditions-with-the-rasterexpressionevaluato.html
Example
Alpha8: if (A[0]==179 && A[1]==227 && A[2] == 249 && A[3]==255, 0, A[3])
If the pixel is (179,227,249,255) set it to 0, otherwise keep the existing value.
you would set the RGB bands to simply A[i] with i being the index of the band.
