gml_id and geometry issues in extending citygml 3
jennychu
Forum|alt.badge.img+4
Hello everyone,
I am a beginner with CityGML and am currently trying to convert a dataset to CityGML 3 with generics extensions using FME Workbench. However, I am encountering a couple of issues:
  1. Warning about inheritance relationship: The output gives a warning indicating no inheritance relationship. I have used AttributeMerge to add gml_parent_id, but the system does not seem to recognize it.
<GML_2 Writer> - '12482' orphaned features found, XML comments representing these features will be present in the output file: <!-- orphaned feature - parent id:'...', id:'...', type:'...' -->
  1. Geometry export issue: It does not export correctly after setting up the geometry. In the Inspector, the data appears as a table without geometry.
Additionally, the original dataset complies with the CityGML 3 standard, and its geometry's encoding is Name (encoded: UTF-16LE). Could this encoding be affecting the process?
My settings and the transformer export are shown in the attached image.
I would greatly appreciate any help or guidance on resolving these issues.
Thank you in advance!
Jenny
Be the first to reply!
