Upgrading from FME FLOW from 2024.0.3 to FME FLOW 2024.2.1.
vivekdey451
Hello FME Community users,
I am trying to upgrade FME FLow from 2024.0.3 to 2024.2.1. I looked into this article
https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Upgrade-in-Place-Same-Machine.htm
Just wondering if there is a better compared to install/uninstall as mentioned above. Such as done on ESRI side.
Best answer by hkingsbury
Unfortunately you do need to completely uninstall FME Flow from a machine before installing a new version. There is no method of incrementally upgrading.
Make sure you create a backup and make a copy of your encryption key before performing the uninstall!
hkingsbury
Forum|alt.badge.img+51
  • January 29, 2025
vivekdey451
  • January 30, 2025
Thanks for the confirmation.
