Is there a way to copy a subset of the workspace based on dependent tasks before a transformer (similar to how the left green arrow works in feature cache mode)>
  • March 29, 2021
  • 5 views
I have a fairly complex workspace that does a few different things. Is there a way that I can select a transformer and copy all its dependencies as well? It's able to do a similar thing when we run the left green arrow in feature cache mode. It'd be great to see an ability to select and copy the objects as well if we want to pull it out into a separate workspace.
DanAtSafe
Forum|alt.badge.img+18
  • March 29, 2021
Hi @Luke Hodgson​ That's a great idea but unfortunately there isn't a way right now to select upstream transformers. This idea seems similar. Maybe upvote that and add a comment to it?
