Thanks for your answer. By islands I mean real islands in middle of water without adjacent polygon. DonutHoleExtractor returns polygon that are completely within a bigger polygon.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
