DXF to KML
Hello,
I'm looking for some help running a DXF to KML.
I've not done this type of conversion before and wondered if there is anything else that should be added to the process?
I'm currently running it on a generating workspace and a dynamic schema to write. The DXF contains:
Point, poly, line, annotation and the coordinate system should be WGS 1984 UTM Zone 29N
Any help appreciated.
Thanks
Best answer by daraghatsafe
Hi @kimburrows1242, there is a template workspace on the FME Hub which works with DWG to KML this may help you out. You may need to change the reader to DXF or export the file as a DWG.
https://hub.safe.com/publishers/safe-lab/templates/dwgfootprintstokml3dbuildings
This blog post may also provide some helpful information.
https://www.safe.com/blog/2015/04/how-to-convert-style-kml/
I hope these resources help please let me know if there is anything else.
Daragh
daraghatsafe
Daragh
Daragh
Thank you!
